I’ve been using a 3 column stack each with a photo and text that link to different pages. Never had a problem. I’m now trying to use a 4 column stack to do the same thing. I set it up exactly as before in edit mode, (See attachment), but when I switch to view mode, it make 4 huge boxes stacked vertically. (See 2nd attachment) The answer must be simple, but I cannot figure it out. Can any of you way smarter than me kind folks figure it out?
Here are two screenshots. Just mucking around, I changed the Fill Mode setting from "“Fill” to “Fixed Size” and then back to “Fill” again, and for some reason, it seems to be working properly now. I don’t know if that was relevant or not, but any explanation about breakpoints or settings would be helpful. I’m always ready to learn something new. I had never used a 4 column stack before. Thanks a lot.
