Adding Font Awesome to UIkit projects
Thanks Stuart. Yes, it would be great if @Isaiah would make this possible (with another setting in the Stacks prefs)… :-)
For some of the built-in libraries enabling it could be a bit tricky. You not only choose the library but you also set a range of versions that will work with your particular code. Stacks now has FA v4 and FA v5 and a range of jQuery versions that stretches back a couple years. I’ll need to have some sort of simplified UI for selecting what you want – such that it doesn’t cripple the other things on the page that might need specific versions too.
But still, I do think it’s a good feature – perhaps just adding the latest version for users? That would be one way to go.
We’re moving as quickly as possible to release, so I don’t know that I’ll get it into v4.0 – but I think we can add it for v4.1.
