“Could not open this Project. Project requires RW 8.1, you have RW 8.03.”
WHAT??
They can’t be serious?!
In this vein — after 250 Beta iterations of RW 8.1 is anyone using it?
Is it safe to use or is it just another unsuccessful beta test?
I’ve not heard any complaints for a while…
I.e. RM takes 2.5 years to develop what is in the best interests of the Weavers, yet is wholly different what was asked for, needed or expected, and then when the Weavers complain with bugs, they take a further (so far) 5 months to come up with a working 8.1 Final Candidate that gets worse and worse with each release. The only luxury that RM have is that there will be no public vote of confidence in their ability to create the “The best web design software for Mac, just got better”.
It’s a bit like Teresa May constantly reminding us that her deal is (was) the best deal.
I do hope that RW8 users who have problems and report them get a speedy return email from RM with a checkbox form to fill in with questions such as:
Are you using the Stacks
Are you using the latest version of Stacks
Are you using SiteMap
Are you using PlusKit
etc
etc
Because the Final release threads appear to be involving Isaiah at a late stage and call be a a crazy maverick, but maybe RM should be talking to Isaiah.
Full marks to Isaiah for controlled public restraint.
Nothing wrong with Beta testing but to call a Beta, a Final Release Candidate, is just bad and misleading practice, unless extensive testing proves there are no known issues and the tested Beta is ready for release.
Betas should have a clear warning that there may be bugs and if there is a file format change that you cannot go back to the old working one, then this should also be made very clear.
Just to be clear…
… I have no problem with beta testing, I do it for numerous developers – not only for RW.
The Final Release Candidate should, however have something to do with the FINAL release and NOT go through 244 iterations.
I just received a project from a Stacks/Theme developer that I’m unable to open because I refuse to install the “Final Release Candidate 245”, but there was never any mention that there is no backward compatibility for RW 8.1
In my opinion, instead of shooting for 8.1, they should be releasing the fixes for 8.0 as an imterim update, then shoot for 8.1 in their own time. As it is, there are people waiting for fixes to 8.0, which I understand to be fixed in 8.1, but these fixes are being held back for problems arising from their desire to sandbox 8.1. Happy to be corrected if that in’t the case.
