One ‘star’ third-party stack per page is a good formula, hitting a sweet-spot between load time and user-engagement. But, of course, not all stacks require Javascript. A stack can be a very efficient way of providing a styled structure into which content can be easily added, and in that respect needs only HTML and CSS templates. In any case, the whole JQuery episode gave ‘interactivity’ a bad rep, with its need to load big libraries, frequently just to power relatively simple functions (and because different versions of JQuery were incompatible). These days even quite complex functions can be written in vanilla JS, without the need for libraries, and these are processed more efficiently by browsers.
Everything can be written in vanilla JS. jQuery is also written in vanilla JS…
That’s true, but extensions to Javascript (particularly in navigating the DOM and targeting nodes), and compatibility in the way browsers handle JS, means that JQuery’s raison d’être has greatly diminished. Plus, the proliferation of different JQuery versions means that its burden is often heavier than it could be, especially in an environment like Stacks, where third-party components come with their own JQuery dependencies.
What’s the advantage of upgrading to Foundry v3? I built all my previous sites in Foundry v1 & v 2? (Also with Alloy).
Perhaps helpful:
Thank you kind sir.
I was also wondering how users of version 2 who upgraded found it?
If you follow the above link it will take you to the support forum. I’m sure if you ask the question where all the people who use F3 hangout you will get numerous honest answers. Sometimes its just best to go to the source. :-)
