I’ll have the other cleaner type of URLs as an option implemented into the Ecwid Customizer very soon, probably today or tomorrow. I can send you a pre-release version as soon as I have it ready, if you’d like to test it…? That way you don’t have to change your whole store design.
Pushed out version 1.1.0 of Ecwid Stacks. This is another important upgrade to improve the SEO friendliness of the Ecwid Store links. This is an advanced feature that requires editing the .htaccess for the website, to add some “server rewrite rules”. If the advance clean URLs option is selected, warnings and some instructions are displayed when in edit mode. In most cases, it should work with the .htaccess rewrites displayed by the stack in edit mode. If things don’t seem to work, it may mean that additional custom editing of the .htaccess file is required. In this case, unless you can figure out the exact server rewrite rules needed, I suggest that this option be disabled.
My question is for the .htaccess
Can the “Store page name:” be ‘on-sale/index.php’?
And what path do I use for “Store folder path” do I use this? draft1.floorsdirectaustralia.com.au/on-sale/
This is the draft website that will be going live shortly.
www.draft1.floorsdirectaustralia.com.au
Ecwid stacks are on 4 pages - Flooring>Hybrid, Flooring>Laminate, Flooring>Engineered, and On Sale pages.
We were only going to setup the 'Enable Advanced Clean URLs" .htaccess on the final site…not on this draft site. But I want to check how to do it so we can get setup once the final site is ready.
To use clean URLs you need not only to edit the .htaccess file, but also add some javascript code to your website, or use the Ecwid Stacks which includes all the code for that and makes it all much easier.
Here is a link that can help you with that if you are not using the Ecwid Stacks:
