I am having a problem with a Poster 2 implementation. When I link to the page using ‘https://domain.name/poster/’ the result is a blank page. I don’t see the posts until I refresh the page, just the page links, e.g. ‘Page / 1 Next’. If I refresh the page, then it displays the posts. If I link to it using this url, then it displays at once with the posts ‘https://domain.name/poster/?page=1’. Likewise, the ‘Back’ link loads this blank page, requiring a refresh to display posts. I do not have this same problem with another almost identical implementation of Poster 2, but I cannot figure out what is causing this.
Please post a valid URL.
Thanks for responding. The page is password protected. I will have to set you up privately with login credentials. Are you the inStacks developer?
Yes
How can I respond privately. The page uses Sitelok to control access. Sitelok requires a user email address.
One thing that I mentioned which is not correct: The posts do not load on page refresh. One has to click on the Next link.
Replied. You’re the first with such a symptom, so my guess it’s related to another stack on the page.
The culprit appears to be Sitelok. I can put ?page=1 in links to the page, but is there any way to do the same with the “Back” link in the posts?
No.
I made a small change to Sitelok V6.1 which seems to fix this issue.
