When I opened RW 8 (v8.9.3) I discovered it is now not previewing either within the app or any browser I choose.
Does anyone know what might be causing this to happen?
Hejsan Yes I experience the same thing once in a while. The simple solution is to erase a frame, then preview, if showing go back and undo the erasing of the frame, and you should be good to go.
Kind Regards
Kent
It happens even if I create something simple from scratch. I just created a simple page with just a paragraph using Source.
Ok, then I do not know what you are experiencing. Try contacting the Rapidweaver folks. Sounds like you might need to reinstall RapidWeaver and stacks.
