It is working now!
Question, what theme are you using?
For RW ?
and for WP?
It does indeed seem to be working now. I can see I need to stick a cache program into the blog…
Theme is an old one from Henk Vessilar (I’m trying to remember his name, and guessing at the spelling) : “HV-XXL-r-left” and in the WP blog it’s Libre. (I tried Blocksy but that was back when I was having trouble. )I have not had time to make any customizations to the theme in WP. It particularly needs a font and size adjust…)
I see a longer delay on this RW theme, I’d like to test if out. Could you Private message me a copy of that theme so that I can test it, once I’m done with it, I’ll delete it.
Also, definitely try Blocksy, as you will be able to highly customize it, but also remove the header, footer, page titles etc. Additionally, you can better match the fonts to your RW site.
Ricardo
Try removing any plug-ins that you do not need.
Also, Litespeed cache plugin does a good enough job. I also recommend the Loginizer plug-in.
