Is it possible to style the text added to a CSV file. I can use <strong> for bold text, what about changing colour too? is it possible?
I use EasyCSV for the CSV table and Joe’s Feeds stack
How would you normally style text in Source? You should be able to use that same method. You simply integrate the content from Feeds using the macros. One of the main points of Feeds and Total CMS is to separate your content from your design.
