Hi there,
is it possible to add an image to a Container Plus stack and then have it ‘stick’ as content scrolls over it to produce a pseudo-parallax effect?
Rob
Hi there,
Rob
Hi Rob - yes in Container Plus you can set a background image to be ‘fixed’. There is a checkbox for that if you select image as the background type.
Ah, got it. Thanks.
Rob
No probs.
Often when using that approach it is useful to also set a minimum height for the container and set it to display as a flexbox (so that you can then vertically center the added content).
Thanks. I need to get my head around this flexbox stuff as it looks really useful.
