Hi, I would like a little help, I always like to learn, I do it only for passion and to help some friends.
example in this page with filter search for “Dante” (which would be the site where I do a thousand tests): DIARIO | Gianluca.Online
The reference design I used is PROJECT24-Demo3 by Gary @Webdeersign
Template List: in the Coder (Source), which is under the Coder ribbon, I have inserted the link {{readmore.link}} in Image Fit (Source)
then clicking the image you get to the Detail, everything ok
unfortunately in the part where the ribbon is positioned the link does not work because the ribbon is rightly positioned above.
I tried to insert the read-more link on the ribbon, I tried different ways, editing and deleting, unfortunately I can’t cover the part of the ribbon with the link to get to Detail.
The Ribbon is very useful and I don’t want to delete it, but I would like the whole part of the image (including the upper right part where the ribbon resides) to take me to Detail.
Do you have any idea how I can fix or give a {{readmore.link}} link to the ribbon as well?
Thank you.
