Hello everyone.
I am working on a blog page with Poster 2 (work-in-progress), and there are a number of problems I need help with. I thought I might post these a few days apart, but if it would be better to post them all in one go, please do say so. Thank you in advance for your help.
Here is the first one, that has been buggin me for a while.
On this page
https://classicalblackbird.net/wedding-music/
the characters " /> appear at the top left of the page, above the nav bar.
On a very similar page
https://notespinner.net/
there are no unwanted characters.
The main difference between the pages is that the Classical Blackbird page has a nav bar (1LD Clean Menu), so I suppose that might be the culprit, but I really don’t know.
Many thanks
What if you remove this 1LD navbar from the classical page?
In addition, you should check your layout for mobile devices.
Thank you for the quick response.
Without the 1LD navbar, the unwanted characters are still present (see screenshot).
Thank you for the note about the mobile layout - I was fiddling around with columns for the Search box and Clear Search button, and didn’t notice how it looked on a small screen. I will correct that.
Who is inserting this into your page?
<link rel="stylesheet" type="text/css" href="<link rel="preconnect" href="https://fonts.gstatic.com"> <link href="https://fonts.googleapis.com/css2?family=Forum&display=swap" rel="stylesheet">" />
Definitely not Poster Stack.
That is the link to the Google font on the page. Well found. Many thanks
Fergus
