Following on from the Boot Camp post yesterday, I discovered that good old Apple (C**ts) won’t support W10 on machines before 2013 via Bootcamp so I went looking for alternatives, and tried Parallels.
I’ve not touched it for years but discovered it actually works pretty well, even on an old 2009 iMac! I was a bit pissed to discover the licence only allows the use on one machine, not what I think has become an industry standard (?) two. So as I only need it to run Outlook for email testing, I’m a bit reluctant to hand over £80.
VMWare, I think, can be run on several machines with the one licence, and is a bit cheaper to boot, so before I dive in, has anyone experience of both, or any other VM app?
I should repeat, I won’t be a heavy Win user: It will get used ONLY to fire up Office/Outlook and test an email.
Quick question: 2009 iMac with 8gb ram. 32 or 64bt W10?
EDIT: Tried both, but it’s asking for a licence key thing. I thought W10 was free to sue now, but I guess not. Weirdly when installing it under Parallels no licence was requested.
Several years ago, I bounced back and forth between Parallels and VMware- it seemed they both came out with updates about the same time, and the deals to switch were much better than the deals to upgrade. At some point, I became disillusioned with Parallels (I really can’t remember why anymore), and settled in with VMware. I’m currently running VMware 10.1.5 / Windows 10. It takes just under 30 seconds from launching VMware until I"m in Windows (I’m on a very fast MBP, though).
Steve,
You should be required to have windows license key no matter what product you’re using for a virtual machine. Unless the product includes the windows license.
You can get a free version (90-day expiration) from Microsoft. That’s probably what Parallels installed.
Office Mac and Office Win only share a visual resemblance and their name. They are written by completely different teams within MS.
I ran/run Win10 without a licence for quite a while, you get a nag screen and things like not being able to change the desktop appearance but other than that it ran/runs exactly as normal.
Just chatted to my server guy, he runs an IT business, he says he has a room full of old systems pulled from clients after upgrades, reckons he can easily sort me with a system, so thinking I’ll go that way.
