A different Navbar question
Hello, I’ve been experimenting with building my navigation menu and am happy with the current look of it (colours, settings etc) but have a question.
I know that if I want to have Nesting pages I have to add these as ‘child’ pages under a ‘parent’ page. The only problem with this is that you have to name the parent page and this will be in the url.
Is there any way round this? With the Foundry Navigation Bar I was able to get around this problem.
Hi @Jake11 -
Yes - the nav bar just picks up the folder and page structure from RW.
If you need more flexibility then there are some alternative menu stacks that a number of source users use. A search of this forum should surface some recommendations if you need them.
