Curious if there’s a stack (or relatively simple way) to create an animated underline of a header that looks like a marker stroke, sort of similar to this:
You have F6. Use the underscore swatch….
https://www.foundationstacks.com/demo/swatch-pack/#underscore
Thanks. Is it possible to get the effect that it looks like a sharpie or highlighter with that swatch? It looks like the site I reference uses an SVG. Should I be trying an SVG / animate swatch combo?
The logo I’ll be using is styled to look like it was drawn with a sharpie and they saw this style of animated underline and liked it.
you can also create a single SVG with text and logo.
With QuickSVG Stack you can animate your SVGs
Prova così
CSS:
.underline-animation {
text-decoration: none;
position: relative;
white-space: nowrap;
svg {
position: absolute;
top: 0%;
left: 0;
width: 99%;
height: auto;
.stroke {
stroke: green;
stroke-width: .3em;
stroke-dasharray: 822;
stroke-dashoffset: 822;
animation: underlineAnimation .7s 1s linear forwards;
@keyframes underlineAnimation {
from {
to {
stroke-dashoffset: 0;
HTML:
Questo testo è
<u class="underline-animation">
<svg xmlns="http://www.w3.org/2000/svg" viewBox="0 0 500 150" preserveAspectRatio="none"><path d="M7.7,145.6C109,125,299.9,116.2,401,121.3c42.1,2.2,87.6,11.8,87.3,25.7" class="stroke" fill="none" stroke-linecap="round" stroke-linejoin="round" stroke-width="10" /></svg>
sottolineato</u>
Wow, thanks for that!
While slightly different, I thought I would build a nice demo of an animated highlight. Actually thinking about it now, you could take what I did and make it super similar to what you want without an SVG. Just need to make the pseudo element a few pixels high and then add an advanced border radius.
Thanks Joe! I’ll give this a closer look when I have some time over the break
In case you need it, since I have half an hour free now, I’m sending you a variation:
- I created the svg with Amadine
- now the animation has a delay of 1 second, it stays for 7 seconds, disappears for 2 seconds, then repeats infinitely (similar to the example site)
- to insert the html I used Scribe by BWD inserting in CSS Classes H1, H2, H3
- with the .stroke you can now modify the animation
- with top: of the svg you can modify the distance from the text.
Scribe:
<u class="underline-animation"><svg xmlns="http://www.w3.org/2000/svg" viewBox="0 0 255 32.61"><path d="M7.29147,8.66539 C7.29147,8.66539,60.2814,5.99571,129.953,5.01441 C199.625,4.03312,247.709,4.90409,247.709,4.90409 C247.709,4.90409,71.5819,8.27282,26.3723,16" class="stroke" fill="none" stroke-linecap="round" stroke-linejoin="round" stroke-width="10" /></svg> **Online private tutoring**</u> to help you achieve your academic goals
CSS:
position: relative;
line-height: 2em;
svg {
position: absolute;
top:.96em;
left: 0;
width: 100%;
height: auto;
.stroke {
stroke: #2EB560;
vector-effect:non-scaling-stroke;
stroke-width: 6 !important;
stroke-dasharray: 1000;
stroke-dashoffset: 1000;
animation-name: underlineAnimation;
animation-duration: 10s;
animation-timing-function: ease-in;
animation-delay: 1s;
animation-direction: normal;
animation-iteration-count: infinite;
animation-fill-mode: forwards;
animation-play-state: running;
0% { stroke-dashoffset: 1000; }
4% { stroke-dashoffset: 0; }
49% { stroke-dashoffset: 0; }
80.9% { stroke-dashoffset: 0; }
81% { stroke-dashoffset: 1000; }
100% { stroke-dashoffset: 1000; }
I hope it helps you.
