Another Grid Layout Puzzle
Hello again… Here’s another puzzle for you UIKit masters (I’m looking at you @Lucas )
I have an alternating ‘text-image’ / ‘image-text’ grid… basic stuff, however mine are alternating down the page.
Like this:
When the page shrinks to one column I need the order to flip on every other pair, so it goes ‘text-image’ every time otherwise it looks odd, like this:
I thought the way to go would be to use ‘.uk-flex-column-reverse’ on the grid, but nothing happens when I do that… Is there a way of forcing the widths to change their order when on small screens?
Thanks folks.
R
p.s. I can do this with ‘Sidebar’ from BWD but would like to implement in UIKit if possible (and I’m sure it will be :-) )
In the Flex stack you can set the “Order” at certain breakpoints.
15
Ah yes… So use the flex stack with cards and don’t even bother with the grid stack… Cheers Neil. I always jump for the grid stack for layout and I probably shouldn’t!
edit: I couldn’t really get that working as the cards won’t stay the size I want… I ended up using Sidebar. Simple and does the job.
I think what you are trying to do is demo’d on the UiKitter Skyline project: https://www.uikitter.com/demos/skyline/columns/
That first grid changes stacking order compared to unstacked. And as Neil says, it’s using the UK-flex-first@x class in the Grid width stack that you want to change the stacking order of.
Hi Steve @steveb-old,
That’s exactly what I want to achieve and weirdly, that’s exactly how I was doing it but for me it wasn’t working. I added ‘uk-flex-first@s’ but nothing happened… Syntax error??
I will have another go… Must be doing something wrong…
I must get around to buying your project too
Most likely you didn’t enable breakpoints?
This is how those columns are setup…
Genius! I owe you a pint sir! That’s exactly the problem…
That’s pushing reality a bit far mate!
