Hi Andrew (and all),
I’m working on integrating Zoom’s web SDK into a RapidWeaver site (F1) and have a question regarding ButtonPlus2. The Zoom dev team has asked me to assign a unique Element ID to a specific button so that their code can trigger a chat window via JavaScript (e.g., id=“zoomChatButton”). I’m using ButtonPlus2 for the buttons on the page.
My question:
👉 Does ButtonPlus2 support assigning a unique Element ID per button?
If so, is this done via the “Custom Class” or “Data Attribute” field, or is there another method? I want to make sure the button can be individually targeted by their script.
Here’s a draft version of the layout in question:
🔗 Enter the passcode to login
🔐 Password: zoom
If assigning an ID directly isn’t possible, I’d appreciate suggestions for how best to proceed — or if another stack might better support this.
Thanks in advance! ~ Dave
Yes, just add an ID to the custom attribute setting. This will add it to the actual button (the stacks ID is only on the outer wrapper)
Hi Dave
This is something that I too am considering - can you please share the Zoom code that should be used.
TIA
Paul
Hey Paul,
This was part of a custom implementation. Zoom initially provided code that added a floating chatbot in the lower right corner of the browser. However, the client felt that visitors might assume it was a general-purpose chatbot, when in fact it was intended specifically for use with their scheduling team.
To avoid confusion, they asked that it be launched from a clearly labeled button embedded within the page content. So, in this case, I didn’t generate the embed code through the Zoom dashboard—their technical team provided it directly.
Thanks again to @AndrewTavenor for pointing me in the right direction regarding element IDs. That was exactly the detail I needed.
