Change color in Repository
Hi, there is a way to change color in Repository text, little icon, enter button, etc? I can change just bar and text color in upper part. Many thanks.
Hi Riccardo,
The colors currently you’re able to change are all.
Cheers
Jannis
Hi Jannis, where the area to change the color? I just see the 2 colors in Repository design… Thanks.
Yes. These are the ones you’re able to change.
