Chroma stack with Source Navigation?
Anyone have experience using BWD Chroma stack with Source Nav stack? I want the ‘initial’ state to be transparent but when I set this in Chroma it becomes White. It then doesn’t respect the ‘triggered’ colour either. Well aware a lot of these great stacks are becoming legacy but thought I’d ask anyway!
Have you set the Source Nav stack to have a transparent background? If so then the colours you set in Chroma should show through.
Yes - that’s how it was to start and then I put it in the Chroma stack. I’ll take another look and report back.
Yes - done it from scratch. I have also set Chroma to be transparent as the initial state but it’s showing as white. The triggered colour is now correct however.
Are you sure it is not just the page background at the top of the page that you are seeing through the nav stack?
There is an option in Chroma to ‘Float’ the fixed menu. if you select that then it should sit above your other page content.
Not the page colour - that’s transparent as I have a container+ with gradient for whole page. I’ll try the float option.
Float option works! Brilliant. Thanks so much.
