Hi, has anyone tried to using one little designer Circle menu stack and limelight? I’m trying to have a menu entry trigger limelight modal. The class works when I try on a regular text stack but when linking with the circle menu stack limelight does not show up.
It could be that the circle menu item is generated by JS and is not present on the page when Limelight binds the class to its open event.
Thank you for your quick reply, I also tried topbox and foundation reveal with the same result. I guess it’s not doable.
