I would like to recreate this screen for a home page, the background with 3 colors, with gradient at the top (the colors will be decided, I think from the top green white and red), and in the middle an image with transparency.
I would like to update a friend’s site using only SOURCE to bring the PageSpeed Insights value from 40 to a minimum of 90.
If I want to use only SOURCE components, can I recreate the page?
How could I do?
Here is a very simple demo of 1 way to do it.
To get that white to transparent fade on the heading, this will do it (to the document Stuart provided, anyway):
h1.stacks_in_22 span {
background-image:linear-gradient(to top, transparent, white);
background-clip:text;
color:transparent;
Nice! I’d go with this to make it a bit more robust / re-usable:
.grad-text h1 {
color:transparent;
Just add the grad-text class name to either the header stack or the grid item (and switch the header colour back to ‘Base colour’ so that the above css can override it)
And maybe pop a cheeky font size clamp in there to scale the heading size with the width.
I’m liking sizing headlines with vw — I’ll have some things to share showing this in due course. vw also produces nice, responsive behaviour with line-height and margins and letter and word spacing and all sorts of other things (including positioning). It’s good for heights, too, as using it in both x and y dimensions keeps everything in proportion. And I’m wondering if it’s really necessary to clamp headlines, because even at 320px something that is 5 vw or more is big enough to have some presence. But I suspect that I’ll be swapping vw for qw when there is enough browser support for container queries.
I’ve been playing around with Stuart’s demo file trying to find a way to put a block of text in either the top (dark gradient) or bottom (white space) sections in such a way that the right or left margin follows the line of the diagonal.
I’ve tried defining a class using various permutations of the shape-outside property with negative shape-margins as shown below, but these seem to only work with floated images. Is what I want to do even possible? Any pointers or advice will be greatly appreciated.
.diagonal-margin-text{
-webkit-shape-outside: polygon(0 0, 100% 0, 100% 19%, 0% 100%);
shape-margin: -120px;
