I’m trying to override the color in an Eternity 2 stack. I have the font color set to white but I would like to have a different font color (046ab8) for the H2 “GET A FREEE QUOTE”
I’m using Foundation and it shows correctly in Edit Mode, but once I preview it, the color changes to white.
Any suggestions?
URL?
hard to help without one…
What stack are you using to add the text? If Foundation header, just select custom colour and set to whatever you want.
It is a Foundation Header stack. I have selected through swatches and custom colors and neither have been successful for me.
Write your header text as:
<span style="color:#046ab8">Your header text here</span>
Mot likely something else on the page rewriting the H tag css to white.
Eternity 2 has an option to set all the text inside including headers to a chosen color. It specifies that chosen color as !important, so it will over-ride most everything inside.
DooBox, you rock!! Thank you.
