Hey folks, I just bought the Azimuth packaged, but it shows up in my RW8 the following, I tried white duck for the Animate but it does not appear to be available… as per the 3/4 columns, should I get the Foundation from JW?:
Are you getting this on a “demo” project?
I don’t have Azimuth, but I don’t think the system requirements don’t say you need foundation.
@Marten?
Hey there, nope, it is in a new project, but the same show up when I open the bundle file…
There’s a list in the download of all the stacks that the project requires. Animate 3D is a child stack of Sections Pro (from BWD) - have you got that one downloaded and installed?
And which version is it that you are using? Foundation, Foundry or Universal? If you don’t have Foundry or Foundation then you should open up the Universal version.
Yupe, I do have the Sections Pro 3.0.9 and I do have the Foundation, and the Universal version is the one opened up…
Hi Emilio
Can you check that you’ve downloaded and updated the latest version of ProStyles. Once you’ve done that, restart RW and Animate 3D should then work.
Marten
Hey there, so I have updated all the installed stacks, and once restarted RW it worked!!!. Thanks for all the help guys :)
Also, if you have Foundation, make sure you’re using the Foundation version not the Universal one.
Same problem- super angry this was an issue in 2019 and it is 2020 and I have the same issue.
The only issue is that the required stacks are not installed. You can get them free here:
https://www.bigwhiteduck.com/stacks/sectionspro/
and
https://www.bigwhiteduck.com/stacks/prostyles/
More to the point, why does this forum think 17 months equal two years?
