I want to switch from blogger to the poster stack. Now experimenting with the stack. But i can not find how to sort the posts on date and time. In blogger and the RW-blog plugin it is just one click.
Any suggestions what i am missing?
greetings dirk
greetings dirk
Currently it is by order inside the stack. First poster item will be also first one to be displayed.
Poster 2 (available soon, free updates for purchases before 01.08.2019) will allow you to sort by date also.
Cheers
Jannis
Is online editing with poster folder also sorted by hand?
greetings dirk
No. You have inside the stacks settings of the poster folder stack the possibility to sort by date or file name if I recall correctly.
Started to try it in MAMP. Thanks for the answer. Now i have to convert my text and documents to Markdown and a fitting poster format. Can do that locally with MAMP.
greetings dirk
