Are the icons you show in Nucleo (including, but not limited to the 3 that are used in the project) available for download?
I ended up acquiring Nucleo with complete set of icons…but can’t find those…
Please advise.
Thx,
Doug
Please advise.
Thx,
Doug
Hi Doug
I put a link to the icon set in the first page of the course (or thereabouts). Let me know if you have trouble finding it.
And Nucleo is a great app. Well worth a download.
Stuart
Got it! Thank you Stuart.
Doug
Hi Stuart
I am a newbie, foundry refugee going through the Lawyer tutorial [ with all add-ons downloaded] I am struggling finding the SVG icons in the free version of the Nucleo app I downloaded. I am 3/4 through the tutorial, grabbing random SVG icons in the free Nucleo app. I just saw the SDR 37 icon and I’m about to download those to do this properly. BUT -as rediculous as this sounds- I cannot find the quotation SVG icons in the free Nucleo, and I don’t see these in the SDR downloads.
Any suggestions as to where I can find them? Apologies for my lack of knowledge here. Adam was good- so good that everything was hand-fed to us. I am also a solo user and never had to push myself further.
Any help would be appreciated. I am very excited to go deeper into source works!
Many thanks
Bob
Hi @cliffhanger -
Thanks for checking out Source. I hope you are getting on ok with it.
I will check out what i reference in the course and update if the advice is now outdated. In the meantime, here is the svg code for the quotation icons used:
<svg xmlns="http://www.w3.org/2000/svg" viewBox="0 0 48 48"><title>left_quote</title>
<g fill="#262626"><path d="M36 14h-6l-4 8v12h12v-12h-6z m-16 0h-6l-4 8v12h12v-12h-6z">
</path>
</g>
</svg>
<svg xmlns="http://www.w3.org/2000/svg" viewBox="0 0 48 48"><title>right_quote</title>
<g fill="#262626">
<path d="M12 34h6l4-8V14H10v12h6zm16 0h6l4-8V14H26v12h6z"></path>
</g>
</svg>
Hope that works for you. Let me know if you run into any further issues.
Thanks,
Stuart
Thanks so much Stuart!
I’m getting on with it. Just a question of more learning on the curve
Best,
Bob
Hi Stuart
Got that first question sorted. Realized those svg icons were in the project package and imported them into nucleo. Sorry for the bother
I’m at the end of lawyer tutorial and stuck on accessing the custom font. I imported palanguin into resources. But when I go to “Custom” I do not see an option to access the font in resources.
I am working with V2.9.2 and assume you were using a previous version in the tutorial.
How do I access imported fonts in the version I have?
I need to buy the pdf manual, I know
Many thanks!!!
bob
Hi @cliffhanger -
Do you have the Source Addon pack? In v2 of Source we switched out the addition of custom fonts to happen in its own stack (the Custom Fonts stack in the Addon pack). Selecting ‘Custom’ in the Source Base stack now doesn’t do anything (apart from allowing you to not specify a font there).
Hope that helps. I think i did add a note about this change in the Lawyer course but it may have been at the start and not at the actual point where custom fonts are used. Apologies for any confusion.
Stuart
I just downloaded the manual, but don’t see it in my order history, and I am not sure how to find the download link .
If you need more purchase information, find my receipt below
many thanks
bob
| Date | 13/03/2025 |
| Invoice number | 1035226 |
| Payment ID | 48937900T0436821R |
| Currency | USD |
Hi @cliffhanger -
If you log into the Academy site you will be able to download it from there. Your logon details will have been set up with the first purchase you made. If you need a reminder of your password you can use the Forgot password option.
Let me know if you have any issues and i can send you a direct download link.
Stuart
Apologies. But I cannot see where to download. Even when I go to my purchases I don’t see it listed.
So, you could send the download link, that would be great. Can’t figure out what I am missing here ?
Bob
If you are logged in to the Academy site then you will see the link to access/download from the Workbook page of the site.
I’ll send you a direct link to the workbook but you will really need to get logged in as there are additional supporting resources. I’ll also trigger a password reminder email for the Academy site to be sent too.
Hi Stuart
Sorted. When I looked at the details in your sign-in email, I realized I had created two accounts. Once in the correct one, I saw the download icon and the release notes updates
Thanks for your help and Scottish patience!
Bob
