Source Elements is a RW8 project file that contains over 50 pre-built web components using only stacks from Source and the Source Addon pack. These are ready to be dropped into any Source project and can be easily adapted to suit your project (there are notes in the project file to assist with this).
You can preview the components using the links below. It is important to note that the categories used here are just to group them in some way. Any component could be repurposed for any use.
Hi @TKslot - only the Source Grid stacks work with the Grid Enabler stack. It is for creating the layouts in other frameworks You would need to replace any Source content stacks with equivalents from the other framework.
Last couple of days to get the launch discount on Source Elements (ends Friday).
It’s been really popular - so much so that I have already started work on Source Elements 2! It won’t be available for a wee while yet but will have at least the following categories:
Headers
Footers
Image grids
I was thinking i might also have a user-suggested category where I could include Source recreations of web page sections/components that you have seen. So if you have any suggestions let me know via email (stuart at shakingthehabitual dot com).
