I am trying to realise a vertical divider line between 2 grid items in a Source page. So a column line in the gutter between two grid items.
i try it at the moment with the grid-plus stack.
greetings dirk v.
greetings dirk v.
Hi @Sprmte - the easiest way to do it would be to add a side border to one of the grid items (this can be controlled at each breakpoint if required). The only way that would look centred though would be for there to be no gapping in the grid. You would therefore need to use padding in the grid items to provide the spacing between content/items.
I give it a try
