Hello
We want to add the store locations that sell our products. Do you know of a stack where customers can enter their location or the product they are looking for, and the stack will return their results?
Make sense?
Hello
Make sense?
Big ask - location or products? Sound like different things. If you don’t have too many locations or products a filter stack might do the job. Otherwise it’s a database solution I would think. If you can be more precise about what you need…?
I agree with @Manofdogs. I suspect that you might need some kind of database solution for this. But you would need to provide more info. My Total CMS product could be a good fit, but again, we would need to know more in order to verify that.
Hello
For example, We have a total of 10 different items and 200 stores that sell these products; however, not all stores sell the same mix of the 10 items.
We know the location and the mix of items each of the 200 stores sells.
We would enter our ten items and the location of our 200 stores into a stack, for example.
Does this help? 😃
Still a very big ask - I cant think of a way to do this without a big chunk of custom development - and you’d need a complete list of postcodes in the relevant areas if you want to give people distances. There are products out there like Blipstar that could do some of this but I’m not sure which would be best for sub-dividing stores that sell some products but not others. There is certainly no stack that does or could do anything like this out of the box.
You can get close using Poster 2 and OpenStreet Map, both from @Jannis
I did some very similar some years ago. I’m not working in my office at the moment, so can’t dig out the file. But it’s for sure doable.
I sure would appercate you sharing how you did it.
Thank you/
