In F6, I’m using MG2 and MM2s on a single page menu. The menu links work but the smooth scroll to page MM2s isn’t functioning… they simply jump to the marker position. I have the MM2 menu inside Chroma Pro but testing with and without has no effect.
I vaguely recall this question was raised some years ago but can’t locate the solution. (Tested the Mouser stack on the same page with no problem.)
Can anyone recall the fix - or suggest one? Thanks!
