I need punctuation letter in TAG links in POSTER STACK, Now is missing.
I have TAG: Křeče.
and link is now: https://www.picomineral.cz/blog/?tag=kee
but right link should be: blog/?tag=krece
When i download your TEST RW project and chande TAG to: čšťžýáí (in HOME page)
slug is: http://127.0.0.1:53188/?tag=cstzyai
and this is perfect… its ok for me.
(I tested this early as I bought the module)
but when i use POSTER it in MY project… TAG: čšťžýáí slug is: ?tag=n-a
why?
I found a problem. when the page is in RW (in the computer) it’s fine …
slug is ?tag=cstzyai ---- http://127.0.0.1:53188/?tag=cstzyai
when I export it to the server, the links will change to ?tag=n-a
where is the problem? what can i do?
I’m not an expert in this, but I had a similar issue (not with Poster) with some German characters (letters). I think it has to do with the encoding.
You could try using the Unicode character for the Czech characters. So instead of ř, try ř. You could also try changing the encoding on the RW page to Latin.
It’s a difficult one related to PHP settings for character codes etc.
I have published now a new version 1.11.5 for Poster Stack (via inbuilt stacks updater) with an additional option to allow non-ASCII characters for titles, categories, and tags.
Please use with care, test thoroughly, and let me know if issues occur.
Slug is changed, but used non-ascii characters now - and some letters yes but some not - its not good for SEO still
For example:
TAG: čšťžýáí
new slug: ?tag=ľščťžýá%C3%ADé (“í” is not recognized still and other characters is with punctation)
the final result must be: ?tag=cstzyai (without punctuation, only “clean” characters - as in english :))
Also in Safari the correct non-ASCII characters are now inserted into the generated tag link, just the Safari browser changes some of the characters by itself.
I hope you understand that special character handling is a pita. There have been reasons that for a long time I only supported ASCII characters in tags.
It doesn’t matter how a link (href) looks like, as long as the display text inside is correct. Google Crawlers don’t execute or follow links like wrong browser implementations. Therefore it’s also not affecting SEO.
For example, take the link I posted above, copy(!) it into you clipboard by text selection (not right mouse click copy link) and paste it into Safari. This browser will automatically change all special characters to their unicode representation.
In order to be able to transfers most of the different language characters into an ASCII representation, I need to use another PHP library, and this will be done in a major upgrade of Poster Stack. There are even some languages where no translation table exists.
