Hi
I wish to have a navigation bar to use with a source site that will allow links to anchors in page and also to separate pages in the site.
I don’t think the nav bar in source allows this.
Can I build a nav bar using the stacks in Source?
Or is there a 3rd party stack I could use?
thanks
Out
I created a tutorial at No 3. Source Navigation example tutorial - building a top navigation layout. This will allow you to add any type of links and build a very flexible navigation.
HI,
thanks for the suggestion. I will look into it.
However I was hoping for a solution at a stack level as I would find trouble shooting your menuOut a bit beyond my skill level.
Out
(Whilst we all wait for Menu Lab…)
Clean Menu from 1LD seems to be the most popular Nav addon that people are using with Source.
Hi,
Any rough timeline on Menu Lab?
Out
Not sure. It’s coming from Tav/Apex not me. I don’t think it is imminent but it is definitely due sooner than it used to be :)
@Outlier Understood. Although a small amount of time working your way through that example will allow you to create powerful navigation that you can then save as a Template stack.
