Looking at the link above, there is a lot more on the page other than the navigation stack.
You have the following stacks listed and an online chat running:
It also looks like you are running the foundation SEO helper page speed. That often can cause JS errors. I would first remove the pagespeed. You have both the new and old SEO helpers running(1.86 Foundation and 2.1.3 New standalone), don’t think that’s the issue but I would probably use one or the other.
Try removing page speed. It moves JavaScript around and often causes other stacks to break.
So just because the stuff in the partial doesn’t create issues with each other doesn’t mean that the stacks inside the partial will not create compatibility issues with other stacks.
If you want to see what is incompatible with each other than you should “unpack” the partial and proceed with a process of elimination.
My best guess though is pagespeed, so that would be the first one I’d remove. If the js error goes away then you’ll know pagespeed and navigation can’t be run together.
I started a new project and selected Foundation as the theme
I added a Foundation site styles
I added the Navigation Stack
I added the old Foundation SEO helper Stack
If I add the “Page Speed” to the old SEO Foundation helped stack I get the same WebFont JS error.
If I remove the “Page Speed” from the old Foundation SEO helper the error goes away.
Nothing else on the page but these three stacks(Site Styles, Navigation Stack, SEO Helper). This even happens in the preview mode.
My conclusion The “Page Speed” part of the older Foundation SEO helper stack and the Navigation Stack are not compatible.
It and like products (CloudFlare’s Rocket) break a lot of stuff. If your hosting plan supports http2 you’re probably better off using that for speeding up site downloading as it doesn’t break things. Unfortunately most shared hosting plans don’t offer http2. You usually have to be running a VPS.
Thank you, Doug! As Navigation has become my go-to stack for menus, I will be removing the Page Speed stack from all of my sites. Fortunately, many of my sites are already utilizing http2, since they are on a dedicated DreamHost server. My sites on shared DreamHost plans, though? Nope - not yet.
