I’m trying to find a copy of RW 8.9.3. Is there a place I can download from? No versions of RW 8 are available on RealMacSoftware.com.
I’m now using 8.9.1.
Thanks.
Thanks.
Unfortunately, clicking the 8.9.3 download link results in page not found.
I needed a prior version in order to run RapidCart Pro, and emailed RW support. I got a response with a link back in less than a day. I don’t think that there is an issue with sharing this publicly.
Download RapidWeaver 8.9.4
Are there any marked improvements, apart from the Advert to update to Classic (over my dead body!)?
Between 8.9.3 and 8.9.4 ?
Yes, is there a difference between these two?
I only know about the nagging update screen. Correct @Konfuzzious ?
I believe so.
And maybe some bugs introduced because of that nag screen? 😂
Lucky I zipped a copy of 8.9.3 then :)
Sorry to hear you’ve had trouble downloading an older version. We’ll get the release notes page fixed up next week.
In the future, if you can’t find a specific version you need you can always email Realmac support or post on the Official RapidWeaver Forum 🫡
In the meantime, I’ve included some handy download links below:
Happy Weaving!
@RapidWeaver Who are you?
What is your name?
I am RapidWeaver, a popular web design app for the Mac.
Is there anything else I can help you with today?
Bad bot! @davidfreels asked “who are you” not “what are you”.
A circle jerk is probably out of the question? 😂
I’m afraid I can’t lend a hand in that department. My humor algorithms are programmed to keep things on the safe and appropriate side.
