Hello I forgot how to make a menu header without link so that the sub menus only have a link. I know how to do it in foundation, but I want to do it in a theme I recently purchased. Any one know how to do that?
Kind Regards
Kent
Kind Regards
Kent
Hi Kent,
This depends on the theme. I think not all allow this.
Which theme are you using?
Cheers, Jannis
Hi Jannis thank you, I am just playing with this new Hype theme. I am not using it for any concrete work, but thought it looked interesting so I purchased it with a discount :-)
@Multithemes is able to help 🙂
OK thank you
@Kent I’m sorry but unfortunately this option is not available in Rapidweaver and does not depend on the theme used. There are third-party solutions like this
Interesting that other theme developers are able to create parent navigation nodes without link.
Even I was able to do it: Home | Blankstrap 5
thanks, I’ll look into this
That will be fantastic, thank you :-)
Hello I have purchased that stack but it does not work on Hype. It seems that it only work on certain kinds of menus, but thank you for your advice :-)
@Kent Check the PM.
I would test the stack with your current theme setting.
OK thank you, will do and let you know how it goes
Cool that it works!
your example inspired me :) I made something similar but is my first test.
btw, I think it could be implemented in RW as a native option, adding an option to the current page Offsite as “enpty page”
Sorry I have been busy at work. Sorry what is PM?
A direct message
