Hello,
How can I use the {{{custom.metadata}}} tag effectively? Where does it pull from, in other words where do I enter my custom metadata into?
Would this be the correct place to add Schema Markup?
When I added my custom custom metadata is it added to the head section of the page?
Bill
In the item there is a custom metadata input field. It comes from Poster 1. No, you aren’t able to put any schema information into this.
Do you have a recommendation for where to place my unique schema information for each of my Poster 2 Items that I create?
Will it be placed in the head section?
You aren’t able to add your custom schema information inside Poster 2.
What metadata and structured data does Poster 2 add, if any?
I appreciate the Help, thank you!
Thank you, very helpful.
Is there away to change the meta property og:type = article tag? Not all of our items are articles.
It would not help to just change this one attribute. The whole schema definition would have to be changed be be a valid document for another type.
