Hej Jannis, is it possible to add a picture to a particular markdown file to be shown as the blog image?
Kind Regards
Kent
Kind Regards
Kent
OK so got the image part to work by linking to the image inside the markdown text file. Not so difficult as I thought it would be. I am more concerned about how I will teach this to the customerâŠ
@Kent Ah ⊠teaching to a customer. Could be easy, could be hard: depends on the person. I have all my students learn markdown and most are fine with it after an hour or so of instruction. A few small number struggle. They are all adults ⊠so more like your client than an 11 year old would be!
I suppose the website you found in another post, Word2MD, might be the better way to go with some customers: I just donât know where that website âfalls downâ with regards to conversion.
# Header image, will be displayed in header content area. Seperate in 2 attributes src and alt, to be added in a new line with 2 starting blanks. Optional.
header_image:
src:
alt:
Hej jannis
Title: Min fĂžrste artikel
Date: 07-05-2021
header_image:
src: https://fbf.one/files/image-local-drop-112.jpg
alt: FrihedsbevÊgelsens FÊllesrÄd
Man kan fremad se, at de har vÊret udset til at lÊse, at der skal dannes par af ligheder. Dermed kan der afsluttes uden lÞse ender, og de kan optimeres fra oven af at formidles stort uden brug fra optimering af presse. I en kant af landet gÄr der blandt om, at de vil sÊtte den over forbehold for tiden. Vi flotter med et hold, der vil rundt og se sig om i byen. Det gÞr heller ikke mere. Men hvor vi nu overbringer denne stÞrrelse til det sÞgeoptimering handler om, sÄ kan der fortÊlles op til 3 gange. Hvis det er trÊet til dit bord der fÄr dig op, er det snarere varmen over de andre. Selv om hun har sat alt mere frem, og derfor ikke lÊngere kan betragtes som den glade giver, er det en nem sammenstilling, som bÊrer ved i lang tid. Det gÄr der sÄ nogle timer ud, hvor det er indlysende at online webdesign i og med at virkeligheden bliver tydelig istandsÊttelse. Det er opmuntrende og anderledes, at det er dampet af kurset i morgen. Der indgives hvert Är enorme strenge af blade af stÞrre eller mindre tilsnit.
Do you have 2 blanks in front of the src tag ?
I also copied this direct from your website, and included a link to the photo, and the photo is not showing.
title: This is the blog title
date: 2018-09-15
categories:
This is my great blog post
Lorem ipsum dolor sit amet, sapien platea morbi dolor lacus nunc, nunc ullamcorper.
Felis aliquet egestas vitae, nibh ante quis quis dolor sed mauris.
Erat lectus sem ut lobortis, adipiscing ligula eleifend, sodales fringilla mattis dui nullam. Ac massa aliquet.
Copying from the website is not recommended.
Use the test project, there is a markdown example.
Yes I have two blanks in front of the scr tag
Ah ok, I was suspecting something like this. I will try from the demo project, thank you and sorry for disturbing you with this.
Ok that also did not work. I found this in another thread on this group, that works for some reason:
title: My first Markdown post
slug: Nothing special
draft: false
tags:
Actually it does not work with the header_image tag. It seems the summary had a link to the photo
Youâre not able to copy and paste the text files here in the forum. The format will get scrambled.
Use the test project, have a look at the files in the resources, maybe copy one of the files and use this as base.
If your still not able to get it running, upload a plain text file here or send me an email.
Ok Jannis, thank you, and sorry :-)
No need to say sorry, all fine. I know the head metadata is difficult and can be frustrating.
I also want this freaking online editor.
Yes such an editor would be a blessing :-)
Good News
I got it working, the markdown editing through Repositorys editing function. I still do not understand why the metadata is working compared with what I did before, but it is working. So I think I just keep this file as a template for the editors to ad content to. I think most people should be able to learn Markdown with a little effort. Oh yes and I learned that the slug is important :-) each article must have a unique slug.
Ich spreche auch Deutsch, Deutsch ist meine Lieblingssprache. Viele DÀnen sprechen Deutsch. Es ist eine wundervolle Sprache. Es ist die Sprache der Welt, die die meisten Wörter enthÀlt. Ich spreche nich perfekt Deutsch, aber Ich verstehe alles. :-)
