Poster 2 template and header Image (UIkit related)
Will do. Thank you :)
Header position
The only small issue I am seeing with the mix of Poster 2 and Markdown posts is the title position.
On Poster 2 the title / metadata is above the header image, on Markdown posts, the title and metadata are below - Am I missing something really obvious, or is it an easy fix? I did look at editing the RW Blog (Poster 1) template, but afraid of making a big mistake!
Thanks,
Nick
All posts look the same. Regardless of stacks or markdown posts.
All depends how you’re inserting the image in either stacks or markdown file.
OK, thanks - I’ll experiment
In MD its src: https://server/image.jpg
In Poster 2 its an image stack in Surrary content
If you define the header image inside the yaml metadata of the markdown file, it will go into the header section. Not in the summary.
Sorry, been involved in other stuff… please tell me what yaml metadata is, I’d be delighted to tidy up my blog and I got nowhere with my own experiments
Once my term as ‘Mein Host’ at the Bed and Breakfast ends, I’m really excited to try this 😊
