I keep getting notified of an update for 1LD’s Quick Editor v1.1.3 , I have v1.1.2
I go through with the update but when I reload RW the version is still v1.1.2 and when I run the update again it still shows update to v1.1.3
Does anyone know how I can get the update to work properly?
TIA Richard
Check the Stack, especially its contents, I had the same problem, then I solved it.
I uninstalled the stack and then downloaded the stack again. It seems that the Quick Editor stack is no longer available and just Quick Editor Global and Quick Editor Wrapper are the only two stacks needed and both these are both V1.8
Anyway it’s all working fine. Thanks for your input @Lukh
