I’ve been using the Repository Stack and it’s been incredibly effective! My clients are thrilled with the way they can interact with their server’s folders, and I couldn’t be happier with its performance.
I’ve been using Sitelok for them to access the URL, but I’m curious if there is a direct URL that can be accessed based on their login information. I attempted using: Login but encountered an error message after entering the login info of any of my clients. It seems to only work with the direct URL. Is there an easy solution for this, or would implementing this feature be a difficult and time-consuming task?
Hi Albert. Can you contact me directly with access to the site to see what you need to do.
I have finished sending you a message.
