Will there be a way to bring RW projects into Stacks 6 or does everything have to be rebuilt from scratch?
In the short term it’ll be this way: Rebuild your pages structure in Stacks 6 (it won’t be named ‘Pro’ by the way), then select all content on a RW page (Command + A), copy it (Command + C) and the paste it into the corresponding Stacks 6 page (Comman + V). So you definitely will not have to start from scratch.
Thanks fo that info.
