Hi out there…
I wonder if it’s possible to integrate CMS-functionality in RWML. For example Easy-/TotalCMS, Go or Sentry or Armadillo or if it’s best to do this the old fashioned way with page per language? I got 4.
Thomas
Hi out there…
Thomas
I am using CMS Go together with RWML: e.g. place a ‘Go Content’ stack into an ‘RWML Wrapper’ stack for each language. The respective content can then be accessed and filled/ edited depending on the language setting.
Hi Gerd,
good idea. I’ll gonna try it like this. And I will try it the same way with EasyCMS. That should work as well.
The client needs to have a "real Admin-area. ;-)
Thomas
Solved! It works also perfect with Easy CMS. See this https://sandkasten.herrschulz.de/CMS/
the admin PW is test
