Scribe and read more
I should know this, but I’ve forgotton it.
I’m using a scribe stack and want to hide the last few paragraphs before a read more link. The content I want visible on load isn’t to be define by a height, ie. 400px, but I want to actually specify the portion of text to have visible initially. ie. I want to control exactly where the read more link goes.
I’ve set the Apply To bit to areas: contained within [] but I can’t get it to work. I thought you wrapped the content to show initially in [[ and ]], but that’s not working. Nor in putting the bit to slow once read more is click inside them working.
Can anyone help?
I’ll not tag Tav, as I know he’s busy with proper stuff, so hoping someone in the comunity can help.
Just tested and seems to work for me when wrapping the content I want hidden in the [[ ]]. Only other setting i needed to change was to make the collapsed height 0px.
Many thanks. I hadn’t set the height to zero.
Thanks.
