Scribe Embedded Links
Any idea why these URLs and emails aren’t working when the syntax is correct?:
https://enrol.nrcac.edu.au/community_music/
Click on “Terms & Conditions”, fourth bullet point is first issue.
There are no links in the rendered HTML. Your markdown has to be incorrect as there is nothing between edit mode text and final HTML other than the built in RW markdown processor.
Looks like you have a space between the square brackets and the round brackets of the link syntax
Thanks tav – thought I’d tried it both ways. So correct syntax is no space?
Correct.
Add a new Scribe stack to the page, the default text has a link in it that shows the syntax. The link also points to the markdown syntax page for reference.
Thanks tav. Now go and do something more clever!
