Scribe, insert a class in markdown
I use Scribe (BWD) and I can’t help but use it… I would feel lost without this wonderful STACK.
Wanting to insert a class to a text or link, to highlight it with a class or play with it with an svg, would there be a way to do it?
I don’t want to use HTML, it would be great to do it directly from Scribe.
Would it be possible?
Or… I don’t want to make Andrew work (a little update 🥹)
This is an example of how I would need it:
from this:
Learn more about [Markdown Syntax](http://daringfireball.net/projects/markdown/syntax)
I would like to do this:
Learn more about <a href="http://daringfireball.net/projects/markdown/syntax" class="svgclasse">
<span>Markdown Syntax</span><svg viewBox="0 0 13 20"><polyline points="0.5 19.5 3 19.5 12.5 10 3 0.5" /></svg>
</a>
result:
Scribe
Instead of inserting the class in the <a> tag, try it in the<span> tag:
<span class="svgclasse">Markdown Syntax</span>
Thanks Marten,
this works perfectly to insert a class,
but my problem is the positioning of the svg, because inserting it like this, then I have to recompile and readjust the css, because everything is moved
in the example:
</a>
<span class="svgclasse">[Markdown Syntax](http://daringfireball.net/projects/markdown/syntax)<svg viewBox="0 0 13 20"><polyline points="0.5 19.5 3 19.5 12.5 10 3 0.5" /></svg></span>
I should readjust all the css, for example the underline created with background-image is not visible.
I would like the css to remain the same.
I’m not entirely clear of the problem but my initial thoughts are:
  1. I’m confused about not wanting to insert HTML into Scribe but then all the examples are HTML? Am I missing something?
  2. In terms of class naming and the hierarchy concerning the SVG; why not just give the scribe stack a custom class and then target all links in that stack (assuming you want a consistent effect on all links)
    .myScribe a>svg{your css}
thanks, that’s perfect, I hadn’t thought of that…
If it might be useful to someone, you can also wrap the element with a class.
<div class="tomato" markdown="1">
## Scribe
### The flexible [Linked Text](https://) text stack.
</div>
Senza nome1
Life in RW / Stacks would be near impossible without Scribe. Thank you @tav
