How can I convince a 2 column stack to stack/display the secound column first on mobile devices?
If you’re suing Foundation or Foundry, there’s an ordering mechanism that you can use. Here’s an example: https://docs.joeworkman.net/rapidweaver/stacks/foundation/layout/column-source-order
I dont think the standard Stacks columns do that but I’m not at my RW comp now to check.
Most column stacks make this far more complex than it needs be. Not Sidebar, which comes with Blueprint from Big White Duck.
It’s a simple case of clicking an arrow to say where you want the 2nd column.
Yes Steve, I know.
I was using Sidebar before and had a Moving Box in it.
Somehow these two don’t work together in my case, so I’m just trying to work out an alternative.
Ah right, sorry, can’t really help then.
Hey,
Thanks anyway.
