Sorry, but it seems I have lost the way I get to the Source (Shaking the Habitual) manual and if there is videos.
Kind Regards
Kent
Kind Regards
Kent
The support page for Source is here https://knowledge.shakingthehabitual.com/collection/4-source
Thank You Mr. Neil :-)
Thanks @Neil
Yes - that is the place to go! It is still a work-in-progress and I will be adding much more to it soon, especially adding some more video content.
Anything you canât find an answer to in the meantime just ask :)
I should add too that I have included quite a few Stacks 4 âtemplatesâ in the downloads (superb addition to Stacks!). These are quite useful for learning about Source too. Along with the project files.
Ok Mr. Stuart :-) Thank You very much. I just started my holiday today, and I am looking forward to play around with âSourceâ in this holyday :-)
Hi!
Another noob question, but I just confused with all this âs-brightâ, âimg-fit-captionâ and so.
Is it exist a full reference to all classes Source use?
Thank you!
hi @Astx
Some of the âeffectâ type classes are available as standard when you use Source (via the Base stack). Details here: https://knowledge.shakingthehabitual.com/article/62-utility-classes-base
A load more are available if you drag the Utility Classes stack on to the page: https://knowledge.shakingthehabitual.com/article/63-utility-classes-addon
I should say that you donât need to use classes with Source - but they can be useful to extend styling options for certain things.
Hope that helps.
