Source Navbar dropdown not working after update *RESOLVED*
Update: this was due to an error installing the stack and not the stack itself!
Just updated the Source Navbar - thanks for tips on CTS. All good except none of my drop-down are working any more. Will play with it now but as it’s a live site thought I’d post this without delay.
Changing the Nav Bar from Sticky to Static has sorted the drop-downs - which were hidden behind content below despite a high Z index.
However, they are now transparent, and not picking up the Nav Bar Background colour as they should
Odd. I’ll take a look. If you can DM me a link to the site in question it would be handy.
It’s a busy live site so I had to restore from backup.
I’ll put it on our dev server in the next 10 minutes: https://kikkdevelopment.co.uk/LCE
Having played with a new page this is what I am seeing:
Static & Sticky
drop-downs work but not picking up any colour, background or custom
Fixed
Entire Menu drops down about 30px and neither main nor drop-down links work at all.
Thanks. I can see the problem. There is a syntax error in the code. Will see where that is coming from and get a fix out asap.
  • RESOLVED * Appears that one or more of my stacks updates did not install properly and this caused some odd behaviour. Having re-booted everything is how it should be!
