Has anyone used Total CMS with Source recently - does it work ok? Are there any potential compatibilty issues?
If so, are there any other CMS options for a Source website?
Hi Jamie
I use Total CMS at source.
It is working fine.
However, when I set the CORE for Total CMS, the text gets smaller.
I use Foundation6 Swatches to set the smaller text.
Otherwise, use CSS to set the text.
I am Japanese and not good at English.
I used translation software.
Sorry my English is not good.
thanks Taku, good to know it works. I can use CSS to set the text. Best wishes, Jamie
Hi.Jamie
Glad I could be of help.
I have had quite a bit of help from Mr. Stuart.
He is a gentleman.
My website.
I would be honored to be of service.
Taku.
TCMS is great complex sites where a blog/blog functionality is needed.
If you need a simpler on-page editor Quick Editor does work well with Source too. I imagine EasyCMS (the more basic version of TCMS) would also work well too, if you needed more basic editing.
Cool, thanks Paul - i’ve not seen Quick Editor before. It looks pretty good and may do the job for what I need. Thank you
