Hi
Is it possible to add a drop shadow to the splider slides?
hi -
there is no support in the stack for that. you might be best applying the drop shadow to the slide content as opposed to the slide itself - i.e dropping a container stack into the Stacks slide, applying the shadow to that (and adding some space / margin to see the shadow) and then obviously dropping your desired content into the container.
i’ll take a note of this and see if it is something that could be added to Splider.
