Splider pagination
In Splider I can’t figure out how to change the pagination from like this:
to like this:
I just can’t do it, any suggestions?
I also tried adding custom css… but nothing to do…
Twice the same picture ? Or is this a test, lol.
Pagination padding-bottom
Now that you pointed it out, it’s obvious, lol. Sorry for me being ‘blind’. Stuart will likely know a solution …
you can see the Splider 2 on this page
(maybe I set something wrong?).
Hi @Gianluca Here is on a photo :
Play with the offset setting in spider style instance. Hope that helps.
Thanks for the help, your suggestion helped me to raise the pagination by 0.6 em at the top, insert a padding in the title and data coder to give space to the pagination, so everything was centered.
Thanks again for the help.
